Results 1 to 4 of 4
Thread: DIY rolling screed for concrete work
    Jan 2018
    Fixitfrank's Tools
    DIY rolling concrete screed, if u use a Milwaukee drill it makes the job extra flat
    The ends of tube are just poly pro blanks slugged out with hole saw turned to press fit, then screwed. Handle is bent conduit along with scraps, it’s done prob 3000 plus square feet screeded, if that’s a word. Thanks so much to homemadetools for all the ideas and plans. Fixitfrank
  2. The Following 7 Users Say Thank You to Fixitfrank For This Useful Post:
    baja (Dec 9, 2020), emu roo (Nov 28, 2025), Jon (Dec 9, 2020), rlm98253 (Dec 8, 2020), thevillageinn (Dec 9, 2020), trigger (Dec 8, 2020), will52100 (Dec 8, 2020)
    trigger's Avatar
    Jun 2018
    Nice,Now if you can give it a bit of vibration????cam,loose weight on slide inside the roller or external coil to apply a striker mech on the roller.ver2.0
  4. The Following User Says Thank You to trigger For This Useful Post:
    Thanks Fixitfrank! We've added your Rolling Screed to our Farm and Garden category,
    as well as to your builder page: Fixitfrank's Homemade Tools. Your receipt:
    Jan 2018
    Fixitfrank's Tools
    Now that you said that I may try a off center hole to add a bit o bounce to it I’ll let you know, thanks Frank
  8. The Following 2 Users Say Thank You to Fixitfrank For This Useful Post:
    emu roo (Nov 28, 2025), Tuomas (Dec 13, 2020)
