DIY Sheet Metal Brake
Several years ago I was refurbing an Airstream trailer. Like most Airstreams the belly pan had disintegrated. The bellypan is one of the important slipstream features of the trailer.
Buying 1mm aluminum was no big deal. Bending it was a nightmare. Wide sheet metal brakes are crazy expesnive and hard to get access to. So I built one out of heavy angle iron for about $150. In all fairness, I did not invent this style, but I was one of the first to shoot a video and help others out.
I did come up with some simple ideas to make a hinge using black (or galvanized) 1/2" pipe and a ground rod. Both easily available from Home Depot.
https://youtu.be/Y84aURyssMQ
Why is it there is hardly ever any ability for full screen to better see these video's? As I believe these are supposed to be a "How I Did It type video"! I love the many video's shown here on this site but they sometimes leave a lot to desired!
Skibo,
When you open the video, also click on 'YOUTUBE' at bottom of player. That will take you directly to the video in YOUTUBE in a new tab, where you can view full screen. Hope that helps you, cheers.
Jim in HOT South Coast NSW, AUS
Feel free to ask questions if you need help with making one or understanding what I did. You can post questions here or to the video.
Thanks Jim, I'll git a try today!
skibo in oh I wish it was warmer in Washington State,USA
Thanks BrianGreul! We've added your Sheetmetal Brake to our Brakes and Presses category,
as well as to your builder page: BrianGreul's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/homemade-sheetmetal-brake-56">
<img src="/uploads/220234/homemade-sheetmetal-brake-56.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/homemade-sheetmetal-brake-56">Sheetmetal Brake</a>
<span> by <a href="http://www.homemadetools.net/builder/BrianGreul">BrianGreul</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/sheetmetal'>sheetmetal</a>, <a href='http://www.homemadetools.net/tag/brake'>brake</a> </div>
</div>
</div>
</div>
