HomemadeTools.net Members
Results 1 to 5 of 5
Thread: DIY a Shopping Cart Key
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    kess's Tools
    You have it in your keys and you never look for coins again.
    A project I had made it some years ago and I had forgets into an HDD till now.
    Unfortunately I did not find any photos of the removable key, and I do not have the original key anymore, because I gave it as gift to a friend of mine, and I never have made it again.
    The reason was to try an idea I had, instead of drawing the cuts on the metal to print them in natural size, on adhesive paper and stick it on metal, for small items I think it's a pretty good solution.
    To begin with, I had to calculate the dimensions that it should have.
    So I started first with the dimensions of the coin (1 euro).
    Thick 2.11mm may be and a little more.
    The highest points were not symmetrically at the opposite sides.
    Diameter about 23.25mm (the coin I happened to have was a 2008 Cypriot coin).
    And then with the dimensions of the simple keys, what interested me was just the total length of the conventional keys.
    Coincidentally, the diameter of the key heads is very close to the diameter of the euro, one was 23.35mm and the other 23.45mm.
    The total length was just over 50.00mm.
    I think that even an old key with a little finish will unlock the cartís lock.
    So having the dimensions was easy to make a plan and try it.
    For the construction I used a strip of stainless steel AISI 430 25x50x2mm.
    We can use any metal (bronze, sheet metal, aluminum).
    I exported the plan to an image file, with a border according to the dimensions of the material I would use.
    I opened a new file on my document editor, and inserted the image file four times, adjusted the size of each image, to the physical dimensions, and printed it on an adhesive paper.
    I cut one and stuck it on the metal carefully.
    Using a center punch Ý3mm I marked the centers of the circles and of the hypothetical euro, as well as the outline of the key.
    So if something goes wrong from the cutting heat: then I would have all reference points and be able to continue in the job.
    In the end, I didn't have any problems.
    The key has tested and unlock the cart just fine, but staying into the cartís lock.
    So I decided to make a new plan for a removable key, thinking that my keys are safer into my pocket.
    The new key has tested and unlocks the cart just fine, after then can be removed.
    DIY a Shopping Cart Key-ff_karotsi.jpg DIY a Shopping Cart Key-00ee_kess_karotsi2.jpg
    DIY a Shopping Cart Key-00-1_kess.jpg DIY a Shopping Cart Key-00-2.jpg 50x25mm
    DIY a Shopping Cart Key-klidi-karotsi-x3-n-3d_kess.jpg DIY a Shopping Cart Key-klidi-karotsi-dimensions-remouvable_kess.jpg
    DIY a Shopping Cart Key-patron_removable_kess.jpg DIY a Shopping Cart Key-klidi-karotsi-remouvable_kess.jpg
    50x25mm
    Advertisements
  2. #2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Advertisements
    Thanks kess! We've added your Shopping Cart Key to our Miscellaneous category,
    as well as to your builder page: kess's Homemade Tools. Your receipt:
    Advertisements
  3. #3
    carousel1's Avatar
    Mar 2019
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have found a wooden ice lolly/popsicle stick does the same job!
  4. #4
    Dec 2015
    Thessaloniki Greece
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    kess's Tools
    Hi carousel1,
    Many things can do the job as well αs the head of an old key a washer and anything object with the suitable shape and dimensions.
    Regards
  5. #5
    Supporting Member IAMSatisfied's Avatar
    Apr 2017
    The desolate ranch country of Northeastern corner of New Mexico, USA
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For those unfamiliar with the grocery store chain ALDI, it's a German chain that has stores in many European countries and even some U.S. states. To use one of their carts, you need to deposit a quarter or a Euro to unlock the cart and use it. When you return the cart to the store, your deposit is refunded. This helps keep grocery costs low.
    I had to look this up, as I was unfamiliar with ALDI and this practice.
    Post your reply!
    eBooks for Supporters
