DIY Static / Dynamic Water Pressure Gauge
DIY static / dynamic water pressure gauge. Allows comparison of pressure and flows. Good for diagnosing pressure / flow issues.
https://www.youtube.com/watch?v=NK6n_PKSWJc
MATERIALS
- Water pressure gauge
- Water filter tap (from home water filter) with valve (opening should be around 1/2 the **area** of the inside diameter of the flex tube)
- Flex connection
- Various adapters as needed to fit plumbing connections (spear, plastic tube, garden hose, etc.)
- Thumbscrew band clamps
- Adapters between things like gauge and 1/2 inch fittings depending on the outlet of the gauge you use.
Re-edit.
