Thread: DIY Super Caulker - High Pressure, Micro Caulking Gun (lo rez)
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    Fixed some "unfixable" leaky wooden windows with this. It's a DIY super-caulker - a re-purposed cheap grease gun and a homemade fitting.
    The grease gun has to be washed clean of oil before use.
    It's only good for 1-2 uses before corrosion and caulk gum it up.
    Be sure to wear eye protection and don't point it at
    anything or anyone when under pressure in case the
    needle blows out.
    Materials Used:
    - Caulk
    - Small / cheap grease gun (well cleaned)
    - Flex tube
    - Brass fitting / drills / taps
    - Inflation needle
  2. #2
    Thanks tsbrownie! We've added your Caulking Gun to our Miscellaneous category,
    as well as to your builder page: tsbrownie's Homemade Tools. Your receipt:
