Hello,
I built a fan that will only blow air into a room when the temperature outside is lower than the temperature inside. Check it out and let me know what you think!
-Michael
https://www.youtube.com/watch?v=T4B6prZZ5io
Hello,
-Michael
Thanks m2rechtin! We've added your Temperature-Controlled Fan to our Heating and Cooling category,
as well as to your builder page: m2rechtin's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-temperature-controlled-fan"> <img src="https://www.homemadetools.net/uploads/225690/homemade-temperature-controlled-fan.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-temperature-controlled-fan">Temperature-Controlled Fan</a> <span> by <a href="https://www.homemadetools.net/builder/m2rechtin">m2rechtin</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/fan'>fan</a> </div> </div> </div> </div>
Dude that's pretty awesome! Cool idea!
If you ever need to do something like that tiny and cheap, you can use two silicon diodes (1N4148) as sensors along with an 8-pin comparator chip and two resistors. You probably need a transistor to help the comparator drive a DC fan directly or a relay for an AC fan. Won't give any readout but will switch fan on/off based on which sensor is hotter.
Thanks for the tips jdurand! I will have to try that out.
