I recently had a couple of different jobs to mill thin material, this video shows the methods that I used to avoid problems and get the results that I wanted.
https://youtu.be/eFwy4Qor-CE
Thanks tonyfoale! We've added your Thin Material Milling Method to our Milling category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-thin-material-milling-method"> <img src="/uploads/249749/homemade-thin-material-milling-method.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-thin-material-milling-method">Thin Material Milling Method</a> <span> by <a href="https://www.homemadetools.net/builder/tonyfoale">tonyfoale</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/milling'>milling</a> </div> </div> </div> </div>
Regarding the second tip, if there's no room for a C-clamp, I've found that securing a couple of screws in the slot, with a washer both above and below the material, can also do the trick.
