I've build a Tormek clone out of scrap metal and a slicer motor.
https://youtu.be/VGuBj1foYNQ
https://youtu.be/AGIH_4rIlqY
Here is Part 3. Now the jig for my chisels is working without water on my shoes.
https://youtu.be/4k259WO4Fd0
Reverse rotation - might work better.
Nice build. One question - where is the wobble coming from on the wheels?
Thanks Sam's Workshop Diary! We've added your Tool Sharpening Station to our Sharpening category,
as well as to your builder page: Sam's Workshop Diary's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-tool-sharpening-station"> <img src="/uploads/220917/homemade-tool-sharpening-station.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-tool-sharpening-station">Tool Sharpening Station</a> <span> by <a href="http://www.homemadetools.net/builder/Sam%27s+Workshop+Diary">Sam's Workshop Diary</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/grinding'>grinding</a>, <a href='http://www.homemadetools.net/tag/sharpening'>sharpening</a> </div> </div> </div> </div>
My chisel grinder is commercial and runs 'forward'. Probably about same FPM, but smaller wheel. Its rest positions chisel more atop the periphery so lessens any tendency of fluid to run down an inclined chisel.
Wet wheels aren't prone to burning edge of high carbon or HSS, so direction isn't too big a deal. Reverse though, will reduce wire edge to burnish flat.
I add two drops of dishwashing soap [hand not machine] to the tray, that increases wetting and flush away grindings. Surely it would worsen drainage off inclined chisel.
How difficult would it be to just turn the motor assembly around to make the wheels run the other way?
In a few days Part 3 will get online. I've build a jig similar to the original Tormek so that the water flow back into the bowl.
The nice thing about ulilising those slicers is that anything that you make with them is better than the original purpose - I have had one that i bought many years ago sitting on a shelf, only used it a few times as they are finicky to use and clean ( I bought a small commercial slicer on an auction for about the same price).
I will have to think of some way to repurpose mine as I am a bit of a Magpie and keep everything.
