Thread: Dodge cummins oil cooler tester
    Sometimes the simplest tools can be adapted to do much higher tech things
    I used a foot operated bicycle pump a tubeless tire valve stem and a small metal pan I made to pressure test an oil cooler
    I placed the cooler in the pan of water and clamped it down covering one of the oil holes then forced the tire valve into the remaining port attached the foot pump then pressurized the cooler
    Dodge cummins oil cooler tester-cimg6806c.jpg Dodge cummins oil cooler tester-cimg6807c.jpg Dodge cummins oil cooler tester-cimg6808c.jpg
  2. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    j2mariashop (Mar 23, 2016), Jon (Mar 20, 2016), kbalch (Mar 20, 2016)
    Thanks Frank S! We've added your Oil Cooler Tester to our Engine category, as well as to your builder page: Frank S' Homemade Tools. Your receipt:
