Draining water with protruding outlet technique.
Shake starting a siphon - GIF
U-shaped PVC siphon - GIF
Shake-starting a siphon - GIF
Simple irrigation siphon - GIF
baja (Jul 31, 2022), nova_robotics (Jul 30, 2022), Ralphxyz (Aug 3, 2022), Rangi (Jul 31, 2022), thevillageinn (Jul 31, 2022)
Moby Duck (Aug 4, 2022)
I have my parts washer tank set up with the protruding drain like that. When I am washing dirty parts, the solvent drains through the elevated pipe. This allows most of the dirt to settle on the bottom of the basin. After it has settled a while, I can remove the extension to drain the solvent, leaving the dirt behind to scooped out of the basin. Have to let it drain slowly so it does not flush the dirt down.
