Drill Press crank wheel
As promised, my wooden version of the drill press table lift crank replacement
http://www.labellenote.fr/file/homem...nk_wheel_0.JPG
http://www.labellenote.fr/file/homem...nk_wheel_1.JPG
When I use this extension table, the original crank will hit the table and not be able to turn.
So I did this wooden wheel, that can be turned by hand as a wheel, or as a crank using the handle.
The wheel is hold on the shaft by a set screw, with a brass threaded insert.
Chesnut tree wood and something like boxwood for the handle.
Christophe
Hi Christophe, nice handle-spindle. :O) :lol:
Thanks Christophe! I've added your Drill Press Crank Wheel to our Drilling and Drill Presses category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="/drill-press-crank-wheel"><img src="/uploads/102457/drill-press-crank-wheel.jpeg" alt="Drill Press Crank Wheel" /></a> </div>
</div>
<div class="title">
<a href="/drill-press-crank-wheel">Drill Press Crank Wheel</a> <span> by <a href="/builder/Christophe+Mineau">Christophe Mineau</a></span> </div>
<div class="tags">
tags:
<a href="/tag/handle">handle</a>, <a href="/tag/wheel">wheel</a> </div>
</div>
</div>
</div>
That's a nicely crafted crank.
Al
