Results 1 to 10 of 10
Thread: Drill press lock and stop nut - GIF
  2. The Following 13 Users Say Thank You to Altair For This Useful Post:
    emu roo (Feb 7, 2022), EnginePaul (Feb 19, 2022), Floradawg (Feb 8, 2022), Harvey Melvin Richards (Feb 8, 2022), johncg (Feb 8, 2022), lassab999 (Feb 9, 2022), LMMasterMariner (Feb 14, 2022), mwmkravchenko (Feb 12, 2022), nova_robotics (Feb 12, 2022), rgsparber (Feb 12, 2022), Saltfever (Feb 12, 2022), suther51 (Feb 13, 2022), Toolmaker51 (Feb 7, 2022)
    Perth Ontario Canada
    This I will make!
    Sep 2018
    nova_robotics's Tools
    Quote Originally Posted by mwmkravchenko View Post
    This I will make!
    Me too. This is a thing of beauty.
    Sep 2013
    Karl_H's Tools
    This I will make!
    How many holes? I think I see 16 on this sample.
    If that is 1/2 - 13 UNC, then 1/8 of a turn (8 holes) would give a step of about 1/100 of an inch (0.009615 inches)
    Quote Originally Posted by Karl_H View Post
    I get 6 in one half of the sliding nut. So that would make 12 holes.
  7. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    emu roo (Mar 26, 2026)
    I am thinking a dowel pin and some loctite, and then make up the stationary holed nut. Laying out the holes and drilling them is not that complicated. A piece of something about 8mm thick or 3/8" would have enough beef to be easy to work with. I think I would do all the drilling and filing before I removed the piece from the original stock. And cut it off with a hole saw. Use the trick I have seen to drill a hole on the perimeter of the O.D. to let out the swarf from the hole saw. I picked up a decent set of carbide tipped hole saws when I was in China a few years ago. I love them. They sure beat a twist drill in anything thinner than 1 inch I can tell you that.
  9. The Following 2 Users Say Thank You to mwmkravchenko For This Useful Post:
    emu roo (Mar 26, 2026), EnginePaul (Feb 19, 2022)
  10. #7
    Sep 2018
    I'm wondering if we can't cheapen up this design a bit. What about replacing the drilled nut with a castle nut? That would save a fair bit of fabrication time.
  11. The Following User Says Thank You to nova_robotics For This Useful Post:
  12. #8
    No reason a castled nut wouldn't work. it would be limited on fin adjustment but that may not be a huge issue for many operations. I personally like a spring-loaded quick nut, and setting my milling cutters to a predetermined depth in the collets, but that's just me
  13. The Following User Says Thank You to Frank S For This Useful Post:
  14. #9
    The only kick in the pants will be that at least on my drill press the threaded column is "D" shaped. So it will require some filling in and then filing to shape. Probably a bit of weld on the inside and then some filing. I am not adverse to a scratch build as it is probably the same amount of time in the end.
  15. The Following User Says Thank You to mwmkravchenko For This Useful Post:
  16. #10
    Yeah, But I would have to have my milling machine running for that. Right now it is in pieces from the move. And my tractor will only be going in the spring. I am not working on my tractor in the winter thank you very much!
  17. The Following User Says Thank You to mwmkravchenko For This Useful Post:
