Thread: Drill Press Using a Mag Drill (times 2)
    Supporting Member tmate3's Avatar
    Jan 2021
    tmate3's Tools
    Some magnetic drills have features only available in more expensive conventional drill presses. These include automatic down and up feed, variable speed, and forward & reverse. The downside to mag drills is the limited throat capacity. The need to sit the unit on the work being drilled is also a drawback.
    I overcame these shortcomings by sitting two mag drills on top of what amounts to chopped off drill presses. Older, American made drill press bases and tables are used with 48" lengths of 2 3/4" OD x 1/4" wall DOM steel tubing serving as columns. 3/4" cold roll plates were welded to the tops of the columns with small ears on both sides to capture the mag drills.
    Both mag drills are BDS German made units. One has variable speed with forward and reverse for automatic tapping. The other has automatic down feed with auto reversing when a hole has been completed. Both units can use either annular cutters or chuck held twist drills. Of course, both mag drills can be yanked off in seconds for use outside the shop.
  2. The Following 2 Users Say Thank You to tmate3 For This Useful Post:
    Priemsy (Jan 18, 2021), trevor_60_r (Feb 24, 2022)
    Thanks tmate3! We've added your Drill Presses to our Drilling and Drill Presses category,
    as well as to your builder page: tmate3's Homemade Tools. Your receipt:
