Results 1 to 8 of 8
Thread: "Drill station" / mount for the mag drill.
    Jyväskylä Finland
    Tuomas's Tools
    Hi
    Wanted to get more space to my workbench.
    So i placed my drills to my old miter saw stand.
    "Drill station" / mount for the mag drill.-fb_img_1508217086949.jpg
    Drawer under the mag drill collects drilling fluid and debris.
  2. The Following 12 Users Say Thank You to Tuomas For This Useful Post:
    bukwessul (Oct 19, 2017), emu roo (May 27, 2026), Home-PC (Nov 2, 2022), Komo (Oct 19, 2017), Little Rabbit (Aug 13, 2022), Make Everything (Oct 17, 2017), n9dug (Dec 11, 2019), Paul Jones (Oct 18, 2017), PJs (Apr 4, 2018), rossbotics (Oct 18, 2017), Seedtick (Oct 17, 2017), Themadone (Dec 15, 2017)
    Thanks Tuomas! We've added your Drilling Station to our Drilling and Drill Presses category,
    A beautiful idea anyone can use here is that simple crude "L" shaped block that Tuomas uses as a drill and tap guide for vertical positioning. My sound wasn't working so I am left a little mystified over the saw and blade used for cutting that heavy hot rolled steel plate.
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by Ed Weldon View Post
    You didn't lose anything when missed the voice, i don't talk in my videos. Saw is this: https://www.amazon.com/Evolution-230.../dp/B002UTPCZM
    Cheaper option is to use 7 1/4" steel blade : https://www.amazon.com/Evolution-Pow.../dp/B002M9D2PM
    In this rage 185b model. It comes with multiuse blade that cuts steel too, but multiblade is little slower when cutting steel. But, it also cuts wood and plastics. Works specially nicely with alumine.
    https://www.amazon.com/Evolution-Rag.../dp/B01N640SBJ
    Note that, evolution saws uses slower 3200rpm speed than regular saws.
  7. The Following User Says Thank You to Tuomas For This Useful Post:
    Tuomas - Thanks for the info on saws and blades. Should work well on another project of mine involving long cuts in .125" (approx. 3mm) hot rolled steel sheet.
    Another comment: Your video is an excellent presentation of what can be done with a magnetic based drill. I'm getting a little old to lift and carry one of those things; but I have a small hydraulic shop crane on caster wheels adapted from a hospital patient lift rated to 300 pounds. The crane breaks down into two sections, mast, boom and hydraulic cylinder and the other a 4 caster base frame.
  9. The Following User Says Thank You to Ed Weldon For This Useful Post:
  10. #6
    Jyväskylä Finland
    Tuomas's Tools
    Continued with this:
    "Drill station" / mount for the mag drill.-1.jpg
    Made a drawer where to keep clamping gears and stuff. No front- or back plate to keep it easier to clean.
    Made from left over sheet metals. 2mm mild steel, 1,5mm acid proof steel (upper part) 8mm flat bar.
    Bends made with my diy brake and riveted with steel pop-rivets.
    Video:
  11. The Following 3 Users Say Thank You to Tuomas For This Useful Post:
    emu roo (May 27, 2026), Seedtick (Nov 1, 2017), Tiny (Nov 2, 2017)
  12. #7
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Tuomas, that is a really sweet setup. I quickly looked for a magnetic drill press here in the US, and the cheapest I saw was $699, so probably not doable for most folks here. Certainly not for me anytime soon, but it's all your fault that I want one now!
    Hi, my name is Bill, and I'm a tooloholic!
    Bill in OKC
  13. The Following User Says Thank You to WmRMeyers For This Useful Post:
  14. #8
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by WmRMeyers View Post
    Bill in OKC
    Yep, those are somewhat expensive.
    My friend has this.
    https://www.expondo.fi/msw-magneetti...r-min-10060431
    Its about 420$ here. But, not suitable for bigger drills. ( Max diameter 1 1/4" ) of course that's enough in most cases.
    I like that best part in my drill is that it can be used with 2" cutter.. bad thing is that good 2" cutter for 2" deep holes cost about 80$ itself.
  15. The Following User Says Thank You to Tuomas For This Useful Post:
