Thread: Drilling harden steel with a hand drill
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    Drilling harden steel 59 RC. with a hand drill In this video i will show you how to sharpen a masonry - concrete - hammer drill bits to cut harden steel I will demonstrate drilling into hardened steel with a cheap carbide drill bits this works well for drilling in to knives or knife making it is preferred to use a mill or at least a drill press but it can be done with a hand drill but i do not recommend it
  2. The Following 3 Users Say Thank You to shopandmath For This Useful Post:
    Andyt (10-24-2020), bigtrev8xl (10-24-2020), glenen (10-24-2020)
    One note of observation I've noticed over time that many of the harder materials can be successfully drilled by using much higher down pressure at the same time using a very slow RPM.
    As you said hand drills are a horrible choice for this task but many times they may be the only option available
    Post your reply!
    eBooks for Supporters
    shopandmath (10-25-2020)
