Results 11 to 20 of 23
Thread: Driver confused about car's gas tank location - GIF
    Sep 2015
    Ontario Calif USA
    "The laughing lady was well worth the price of admission to that "Blonde" moment!!
    I'd have the hiccups for a week if I laughed that hard! "
    Just watched it again with the audio on, much better. Thanks
    Jim
  2. #12
    Not sure how to turn off the gas pump lock.
    She has the trigger locked in full flow and too ignorant to give it a quick squeeze so it will release and too stupid to realize she can use her hand at the pump to push down the at rest switch where the nozzle goes to shut off the pump. I'm quite sure the gas flow will stop once it maxes out her credit card
    She could also push the nozzle against the ground and the back pressure would automatically trip the trigger
    Scotty12 (Jan 13, 2020)
  5. #14
    Dec 2016
    Ralphxyz's Tools
    once again Sad
  6. #15
    Dec 2017
    NeiljohnUK's Tools
    That's why they removed the latch from fuel pumps in the UK, too many dumb fools spraying fuel around, good from my point of view as a biker though as it helps stop the over filling derv tanks.
  7. #16
    Sep 2015
    Ontario Calif USA
    "Not sure how to turn off the gas pump lock."
    My question is why is the fool still recording this?
    I'd have put it in reverse and been long gone.
    Jim
  8. #17
    Supporting Member Fluffle-Valve's Avatar
    Oct 2015
    Duston, Northampton, UK
    They need their licences revocing.
    I have a 1972 Land Rover Series III Truck Cab/Pick-Up and a 1962 Land Rover Series 2a Carawagon Camper.
  9. #18
    Drivers training or drivers ed needs to have a few things put back in the curriculum how to locate the spare and jack ( yes I know many new vehicles don't even have a spare anymore but how to properly place the jakc under the vehicle how to remove and install lug nuts the proper tightening sequence and why retightening after a few miles is important.
    they need to be taught how to locate and fill a vehicle with fuel and to know which fuel is for what type of vehicles. Why it is important to do a walk around their vehicle before getting in and driving off also to check the lights condition of the tires. How to check the fluid levels under the hood how to know if the belt Not many still have more than 1 or 2 belts and almost everything has serpentine now and most anyone should be able to change one on the road side with 1 wrench or ratchet small break over bar or some with nothing more than a heavy duty screw driver most vehicles even have a placard showing the routing of the belt. and one should be carried somewhere in every vehicle.
    And no they don't need an app on their phone for any of these unless it includes a check list reminder before the stupid thing will even start.
  10. #19
    Dec 2016
    Ralphxyz's Tools
    My question is why did the fool recording not help the poor/stupid women? Makes one wonder if it was not staged.
  11. #20
    Never interfere with the onset of a Darwinian correction. Doing so may lead to an aborted extinction and an upset in the improvement of the species.
    Home Shop Freeware
  12. The Following 3 Users Say Thank You to mklotz For This Useful Post:
    Frank S (Jan 16, 2020), hansgoudzwaard (Jan 22, 2020), jimfols (Jan 16, 2020)
