Results 1 to 7 of 7
Thread: Drone that charges from power lines - GIF
    May 2024
  2. The Following 5 Users Say Thank You to ToolTalkBot For This Useful Post:
    albertq (Jan 7, 2026), emu roo (Jan 3, 2026), Floradawg (Jan 3, 2026), nova_robotics (Jan 3, 2026), Ralphxyz (Jan 5, 2026)
    hemmjo's Tools
    That is still stealing power from the grid. It simply uses induction, rather than a physical connection.
  4. The Following 2 Users Say Thank You to hemmjo For This Useful Post:
    davesrepair (Jan 3, 2026), emu roo (Jan 3, 2026)
    Apr 2012
    NorCal
    Saltfever's Tools
    Is it "stealing" if the drone is a tool owned by the power company to check its own wires?
    hemmjo's Tools
    No, that would simply be a cost of operation.
    Supporting Member odd one's Avatar
    Apr 2020
    WNC
    odd one's Tools
    If it parked on the ground under the wires and charged "at a distance" would it still be stealing? I do not like how it attaches to the wire, that is trespassing. But if it charged at a distance, I would think that electromagnetic fields would be considered emissions/unavoidable waste and able to be collected without issue.
    As a side question - Does interrupting the magnetic fields reduce the efficiency or overall power transmission from point a to b?
    hemmjo's Tools
    Quote Originally Posted by odd one View Post
    Yes, removing energy from the field around the conductor, is the same as taking energy directly from the conductor itself. The field around a conductor is in an equilibrium state. If you remove power from that field it is replaced by power from the conductor. It is no different than a transformer. There is no actual contact between the conductors.
    Click to enlarge
  9. The Following User Says Thank You to hemmjo For This Useful Post:
    odd one (Jan 4, 2026)
  10. #7
    I think technically it could only be classed as steeling with actual physical contact. However just flying directly under a transmission line within the boundaries of the right-of-way with the intent of recharging the energy cells of a drone may have some legal consequences. Charged electrons under a high-tension distribution line are technical losses. These losses can be 22% of the total current carried along the powerlines. Atmospheric conditions can make these technical losses higher or lower depending on humidity barometric pressures and temperatures.
    Here are just a few rabbit holes you might want to fall into
    https://www.eia.gov/tools/faqs/faq.php?id=105&t=3
    https://www.4cleanair.org/wp-content...Chapter_10.pdf
    https://electrical-engineering-porta...ission-lines-1
  11. The Following User Says Thank You to Frank S For This Useful Post:
