Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Drum toothing - GIFs
    Here's the full set of 22 GIFs, in the order that I found them, including the two above. The first one will autoplay. Click the others to play.
  2. The Following User Says Thank You to Jon For This Useful Post:
    nova_robotics (01-11-2021)
  3. #12
    Lake Tahoe
    IntheGroove's Tools
    Is that felt?
  4. #13
    Supporting Member mlochala's Avatar
    Nov 2012
    mlochala's Tools
    We used rolls like that at a company I used to work for. The company I worked for made the molded acoustic panels that go inside the trunk of a car.
    Raw fiber is dumped into a hopper (like thick cotton candy) and then goes through a series of rolls with varying amounts of pressure and through rolls like this to process the material before it goes into a massive loom. Those teeth will cut you to shreds. It's very similar to razor wire. They have to be replaced whenever they show excessive wear or get a lot of build up (think melted plastic). They are wound onto the rolls with a lot of tension and fastened into place as one continuous thread. The rolls we used were well over ten foot long (or wide, depending on how you look at it).
    If you want to see a mess, let something go through there (like a lost wrench or someone's keys) and break that wire while the machine is running. It goes everywhere and is a terrible chore to remove, not to mention the obvious cut hazard.
  5. #14
    Sep 2018
    nova_robotics's Tools
    Nice welding job on #6 .
  6. #15
    Oct 2016
    old kodger's Tools
    Looks to be exactly what I need for a plastic shredder I need to build someday so I can prepare to melt down over 200 lbs of drink bottles
    Now you wouldn't be going to make pyrolized plastic, diesel would you?
  7. #16
    May 2015
    Tasmania, Australia
    Bony's Tools
    And what are you going to do with that much melted plastic Frank? (And I bet you were waiting for someone to ask)
  8. #17
    Dec 2016
    Ralphxyz's Tools
    200#s of plastic bottles would pay to take them to a state that gives you nickel for a bottle return.
    Ralph
