Results 1 to 8 of 8
Thread: Dump truck pulling post out of ground - GIF
    Altair's Avatar
    Dump truck pulling post out of ground.
    Pile extracting machine - video
    Vibrating pile remover - GIF
    Pile driving on soft ground - GIF
    Vibratory pile driver - GIF
    Hydraulic pile breaker - GIF
    500 Tool Plans
    EnginePaul (Aug 6, 2022), nova_robotics (Aug 4, 2022), Rangi (Aug 5, 2022)
    Use what you have to get the job done, Sure beats a tractor jack
    Homemade Tools eBooks
    Concreted fence post, but close enough. I have brush stumps to pull this weekend, there has been just enough rain to make feasible. Attack will be trailer receiver, 4WD, a jackpole, burlap and 5/16" tow chain.
    Pictures will be taken; shared if not a howling failure. There's about a dozen, so probability says with a few tries, at least one will finally become presentable.
  5. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Altair (Aug 5, 2022)
    hemmjo's Tools
    Depending on how much force you need to break the load out of the ground, that is a good way to ruin a dump truck. The hydraulics are powerful, but intended to lift a load that is pretty much balanced between the side walls of the dump body. Obviously the trick worked in that video. With any big equipment, just because it is big and powerful, does not mean you cannot break. Powerful machines are powerful enough to hurt themselves when used improperly.
  7. The Following User Says Thank You to hemmjo For This Useful Post:
    Dec 2017
    NeiljohnUK's Tools
    And anyone stood in range of the flying debris/hydraulic fluid jet...
    Sep 2015
    Kansas
    It would have been a lot better for the truck, and had better leverage, to back up to the post, raise the bed, then tie the chain off on the center of the gate, then lower the bed.
  10. #7
    It really doesn't take a lot to pull a cemented post out of the ground providing the bottom of the hole was not belled to a larger diameter than the hole itself. Once the initial suction and friction has been overpowered you are only lifting weight. Raising the bed about half the way then using the top of the tailgate allowing the weight of the bed to come back down using only gravity that is one way. Connecting off the side of the bead near the front will obviously allow for more travel, it's not likely there would be much more stress if any, on any part of the truck as raising a load that was loaded higher to one side than the other would do.
  11. #8
    Quote Originally Posted by Toolguy View Post
    Visualizing this one would be my pick. Can see a length of angle iron over top of gate to distribute load on sheet metal, and no real load on the hydraulics at all.
    Tube Bender Build Guide
