It’s a challenge to get to the air drain on my air compressor so I made it easier. An auto drain would be nice but they’re a little spendy:)
https://youtu.be/M2uPk2lOy20
Thanks Sgbarker! We've added your Air Compressor Drain Valve Extension to our Air Compressors category,
as well as to your builder page: Sgbarker's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-air-compressor-drain-valve-extension"> <img src="/uploads/227993/homemade-air-compressor-drain-valve-extension.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-air-compressor-drain-valve-extension">Air Compressor Drain Valve Extension</a> <span> by <a href="https://www.homemadetools.net/builder/Sgbarker">Sgbarker</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/air-compressor'>air compressor</a>, <a href='https://www.homemadetools.net/tag/valve'>valve</a>, <a href='https://www.homemadetools.net/tag/drain'>drain</a> </div> </div> </div> </div>
thats a great Idea
One of the main causes for compressor tanks going bad is the drains are so inaccessible most folks don't drain theirs regularly
well done sir!
I have never understood why the manufactures do not apply a coating on the interior of pressure tanks to prevent rusting.
You are right Frank
I did the same thing years ago, using 3/8" copper tubing and a 1/4" ball valve. The ball valve is much handier to operate than the original type.
This post reminded me I needed to blow my tank out. I had replaced the original drain valve as well with a street ell, and ball valve with a hose barb for rubber hose. I opened it up and water came out, but the flow continued with water vapor, and then the flow stopped as the expansion of air resulted in ice forming in the drain line. I've noticed before that the water vapor will never really stop being seen. I'm assuming it is in the compressed air, and condenses out with the expansion.
yes I usually just drain mine until the sound changes to a high pitch. But I don't use my compressor every day so normally I will drain it at the end of the day and sometimes just allow it to blow down completely. When I get my larger compressor on line then it might have an auto drain dryer from a truck so it will spit every so often the tank will still require draining periodically though.
I'm thinking of buying a CONRADER Auto Drain Valve. Only thing is I would use copper in place of the plastic tubing. It's around $57USD currently.
https://images-na.ssl-images-amazon....j%2BqZu7-L.jpg
That’s a great question!
Hi, I used one of these delay timers, it works a treat :) and real cheap
https://www.ebay.co.uk/itm/H3Y-4-DPD...WzQ:rk:11:pf:0
This is the valve I have fitted to both of my compressors back in 2017 and they work really well and cheap as chips. Only down side very noisy when discharging, but can be set on two timers: 1st how often to open 2nd how long to stay open. At £14-ish great investment.
https://www.ebay.co.uk/itm/1-2-Autom...YAAOSw9A5bqxQK
The Home Engineer
Great idea! I recently added a pipe with elbow & drain valve but I like the hose idea better! Guess I'll have to jack my air compressor back up again now... :sweating:
good idea
I will use this on my next compressor
This is how I done my compressor..
https://www.youtube.com/watch?v=THO27p1r_j4
It’s been working really good so far and I drain my compressor more often!
Nice job on the auto drain. I’ve used many of them in the field over the years and found that they tend to get gummy and sticky and leak. I end up having to take them apart and clean them and sometimes even have to replace them. I hope yours holds out for a really along time!
I worked at a Dodge dealership back in the late 80's as a mechanic. When I started working there I noticed that my air tools would be spitting water all the time and I figured it was just time to empty the compressor. I was rather dismayed to find out that the drain had broken a number of years ago, and the shop decided to do nothing about it. Well, I spent good money on my tools, so I thought I would repair the drain valve, using some parts and pieces from our parts bins. When we got the old valve out we found that the compressor must have been half full of water, rust and general nastiness. It took about an hour for it to finally drain out. After that, we decided to have a schedule for the last guy out to drain the compressor. After that things worked so much better.
Home depot carries an 18 inch long braided stainless steel hose, with the 90 degree elbow on the end, and the valve on the outboard end of the hose, for $18.
Being lazy, I went that route, but replaced the valve on the end of hose with a 90 degree ball valve, easier for my old arthritic hands to operate that way.
Just checked, over the years the hose kit has gone up in price, now $25.98.
https://www.homedepot.com/p/Husky-Ex...023H/205183928
They all look the same in the pictures, here is the cheapest I found:
https://www.amazon.com/dp/B00QQL2BPY
$4.99 prime
Even when accessible a lot of people just don't bother, in Academia CBA is all too common. We made a frame to tumble small lab 'silent' compressor tanks with s/s nuts as the cleaning medium to remove surface rust before treating and pressure (hydraulic) testing them. One was so full the compressor hydrolocked, even though the lab SOP specified the 1/4 turn valve should be opened and the tank drained daily.
Our main system compressor receiver, 9 feet long and 6 feet diameter has electric solenoid vales triggered by an internal float switch in the valves housing, as does every other drain from the compressor, the air passes through a drier so or dew point is ~-30°C as a lot of the kit it's used in/for is very moisture sensitive.
