Results 1 to 10 of 18
Thread: Easy furnace burner for propane forging
Hybrid View
    Supporting Member Drew1966's Avatar
    Oct 2016
    What size is a #57 drill bit please?
  2. #2
    Sep 2012
    Hinchinbrook QLD
    Quote Originally Posted by Drew1966 View Post
    Here you go Drew.
    http://www.smithbearing.com/images/p...ionalChart.pdf
    And I found that on google faster than it would have taken you to type your question
    No charge, Phil
  3. The Following 3 Users Say Thank You to 12bolts For This Useful Post:
    MountainMan (Aug 14, 2018), olderdan (Dec 12, 2018), PJs (Aug 15, 2018)
    May 2018
    Forge burner
    I believe it is the same size as a #4 screw. I just drilled a hole and tapped it using the #57 bit. If I can find another screw, I’ll measure and post the size.
    Download plans for forging and casting tools.
