My favourite quick go to solution for everday use - bore, face. & outside diameter.
https://youtu.be/kK6uVmX97iQ?si=fLYcWXymFQD4Pvc7
Thanks Mook! We've added your Easy Indicating Method to our Measuring and Marking category,
as well as to your builder page: Mook's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-easy-indicating-method"> <img src="/uploads/275843/homemade-easy-indicating-method.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-easy-indicating-method">Easy Indicating Method</a> <span> by <a href="https://www.homemadetools.net/builder/Mook">Mook</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/dial-indicator'>dial indicator</a>, <a href='https://www.homemadetools.net/tag/indicator-holder'>indicator holder</a>, <a href='https://www.homemadetools.net/tag/tailstock'>tailstock</a> </div> </div> </div> </div>
That's awesome. I'd use that.
What kind of dial indicator is that? You're just moving the contact point around. I've never seen that before.
The indicator shown in the video is a Verdict T8, which I’ve been using for nearly 30 years. These models come with integrated pivoting spigots and usually offer a total travel range of about 1mm. Recently, I picked up an Insize 2480-16, which also has an integrated pivoting spigot, this one positioned at 90 degrees to the dial face, and it offers a much larger travel range of 4mm.
I haven’t come across any other brands that include an integrated pivoting spindle, which I’ve found essential for this style of indicating. On the Insize model, I swapped the original round spigot for a hexagonal one so it would fit my quick-release holder. This setup magnetically clamps to my CNC mill spindle and keeps the indicator stylus always moving toward the spindle’s centerline ( essential for small holes ).
With the Verdict model, when mounted in a drill chuck on a milling machine, it naturally aligns with the machine’s centerline and has sufficient swing to effectively tram the table.
I’m by no means an expert, but I’ve spent a fair bit of time exploring different indicator setups. If you’re interested in this kind of thing, there are a few other unique solutions I’ve shared on my channel that might be helpful.
