Results 1 to 4 of 4
Thread: Electric Crucible Furnace
    hemmjo's Tools
    I have been wanting a foundry in my shop for a long time. I had one
    in the shop where I was teaching for 30 years and miss the functionality
    one provides. This post will address the furnace structure. I investigated
    the terms Furnace vs Oven. The best explanation I found here;
    https://kindle-tech.com/faqs/what-is...rnace-and-oven .
    In a nut shell, the main difference is the temperature range, and there is some overlap.
    I investigated fuel options; wood, coal, gas, electric, and construction options;
    pit in the ground, outside above ground, free standing portable. After experimenting
    with various propane burners they are loud, temperature is not easily controlled and propane is not cheap.
    I finally settled on a freestanding electric model which could be used inside or moved outside.
    Two major deciding factors was the ease of temperature control with electric and the collection
    of items I have collected over they years. (Have to start using those things before…. I am too old to use them!)
    I have read most of the threads on homemadetools.net for inspiration, and give credit
    to the many that have done this before. The most recent is;
    Heat Treatment Oven (with separate control cabinet)
    While Dr Al’s control box is much more sophisticated then mine, I got still some ideas from that. I will
    address my control box in a separate post. I am still refining things.
    Design was influenced considerably by items that I have been collecting over the years with
    an eventual foundry in mind. The most influential component was the fire brick from an old
    ceramic kiln. Similar to this one. The one shown is an octagon.
    The kiln I got parts from was a decagon.
    The parts I have are from the art department where I taught.
    It had been over fired, declared unsafe for use in the in the
    school and discarded. I could not resist taking it home. I was
    only able to rescue the top, the bottom, and one section. The
    rest was trashed before I got to them.
    Top, and remnants of the bottom after I cut it
    up to make a top and bottom for the furnace.
    Each section of the original was built from 20 bricks.
    Each brick 2 1/2 x 4 1/2 x 9”. Many of the bricks were
    broken but I was able to salvage a enough good pieces
    to make what I needed and have a few extras left.
    There were 2 - 14 ft heating elements coiled with 14 gauge
    Kanthal wire. The coils were too brittle to reshape. Also the
    wire is to large a gauge to use in my small furnace. But I will
    save it anyway in case I can learn how to anneal it.
    One original brick, 2 1/2 x 4 1/2 x 9 yielded
    two 2 1/2 x 4 3/8 x 4 1/2 segments.
    Eight segments were assembled into one octagon
    layer. The segments are held together by stainless
    steel hose clamps. Two of those octagons provide a
    chamber 5 1/2” diameter by 9” high which will
    accommodate a piece of 4” schedule 40 steel pipe
    for the crucible. (from my “junk” collection)
    To hold the sections together and attach a lid, 1/16 x 1 x 1 steel
    angle was used to build a framework. I collected this material
    from the trash behind Tractor Supply. There is 3” of air space
    around the heat chamber to provide space for loose pearlite
    insulation if necessary.
    The top section is held in place by a frame inside a larger
    external frame. The top of the brick is relieved so the brick
    is flush with the steel.
    The bricks for the top and bottom where salvaged
    from the bottom of the donor kiln. The bottom frame is
    similar to the top with reinforcing bars added
    to support the fragile brick and weight of the filled crucible.
    The bottom section just sets on the bottom bricks,
    it is held in place by tabs welded to the bottom frame.
    Also notice the element ends through holes in the brick.
    The lid has a hole to vent fumes when necessary,
    allow adding material, adding flux and skimming
    the melted metal. The top half of the lid frame is
    extended to provide a hinge point for the lid. The
    screws that hold the lid “sandwich” together also
    hold eye bolts for handles.
    The lid plug is two pieces of brick held together
    with an eye bolt. The black is soot from the burning
    of paint from the aluminum cans I melted during
    the first test firing.
    The two frames are held together with 4 flathead
    machine screws. The screws are set flush with the
    bottom of the frame.
    The ends of top lid frame extend to the rear
    to meet uprights for hinge points.
    When the lid is open, a plate on each side with 2 machine
    screws for pins hold the lid up and prevent it from falling
    backward when open.
    The backside of the furnace is reinforced with a
    crossbar that supports uprights for the hinges
    and the thermocouple probe.
    The probe slides through a groove between the
    two layers of firebrick. I am not certain this is
    the optimum place, but there are not many options.
    Time will tell.
    The crossbar is hidden by back panel.
    The high temperature connections are made
    with ceramic junction blocks. The 4 individual elements
    are wired in 2 pairs of 2. (This turned out to not be a good idea.)
    The high temperature wire passes through the sheet metal panel
    in a smooth flared copper tube.
    The copper tubes are secured inside the control box with
    sleeves and set screws. The fiberglass insulation
    is tough but frays easily when stripping for connections.
    A drop of super glue massaged into the insulation
    before cutting and stripping solves that issue.
    USE GLOVES for that.
    The completed furnace ready for testing. Plans were
    to have the control box separate, out of the way of hot
    processes. When attached to the furnace, the controller
    is too low for my old eyes to get a good view and
    to access the buttons for adjustment. But I did not have
    the components to make it remote, so I mounted it on the furnace
    to allow testing things.
    Initial testing went ok. Everything worked. It took
    me a little time to figure out the programming on
    the InkBird ITC-106VH PID controller. But after my
    fat fingers learned with each button was for things
    went smoothly.
    It soon became apparent that I had pushed the
    limits of the heating elements too far. While the
    furnace heated up quickly the elements were
    getting too hot. You can tell by the color that the
    elements are much hotter than indicated on the
    controller. The sensor is not able keep up with the
    temperature of the element itself.
    I was able to melt some pop cans on the low setting
    which is 1440 watts. This kept the elements cooler but
    was VERY SLOW reaching temperature and recovering
    when adding more metal to the crucible.
    And cast some ingots
    After the first melt, knowing I was going to have to
    remake the elements anyway I started another melt
    on the high setting, 5760 watts. This worked very well
    for a while. But soon the elements began to burn out.
    Leaving me with this.
    And this.
    Currently waiting for new element wire to arrive.
    I will update and provide controller information soon.
    Other threads related to this;
    Easy Follow Rest
    Welding Chill Plates
  2. The Following 7 Users Say Thank You to hemmjo For This Useful Post:
    BuffaloJohn (Apr 20, 2025), clydeman (Apr 28, 2025), emu roo (Apr 22, 2025), Jon (May 14, 2025), mwmkravchenko (Apr 22, 2025), nova_robotics (Apr 22, 2025), rebuilder1954 (Apr 22, 2025)
    Thanks hemmjo! We've added your Electric Crucible Furnace to our Forging and Casting category,
    as well as to your builder page: hemmjo's Homemade Tools. Your receipt:
    Perth Ontario Canada
    A great way to melt stuff. Less hydrogen entrainment melting this way too. You'll find that cans are almost pure aluminum. And they will machine like gummy bears. If you wish to tinker, a little copper and zinc will alter that problem. You can figure it out via weight ratios from an alloy chart. Funny thing. Most aluminum cans are made in China. Wonder how that's working out.
    I have been toying with exactly the same idea. And also an oil fired furnace to melt cast iron. But that is a lot heavier stuff to play with. So first an over arm gantry is in order.
    Mark
  5. The Following 2 Users Say Thank You to mwmkravchenko For This Useful Post:
    clydeman (Apr 28, 2025), hemmjo (Apr 22, 2025)
    hemmjo's Tools
    Furnace repaired and back in service. Plus controller description as promised.
    Electric Crucible Furnace Update
    Download plans for forging and casting tools.
