Electric dent puller
Has anyone here ever made a dent puller like a stud gun but doesn,t require the studs? I saw one somewhere on the net and thought it was here but cant find it. It looked like the old style screw dent puller but the tip was rigged to weld its self to the metal slightly. Looked kind of interesting and seemed to work ok too.
Hi danny42984 - welcome to HomemadeTools.net :welcome:
Interesting question; I'm going to see if any of our car guys know the answer.
I have seen a tool like that commenlly refered to as a nailgun , this tool spot welds a nail to panel then you attach a puller / slide hammer to pull dents out, use 1 or many nails . Not carpenters nail , special nail that comes with tool, I can find details if needed.
Hi,
Do you speak about something like that?
http://www.homemadetools.net/forum/c.../2017/07/1.jpg
Gyspot 2700 Steel Dent Puller.
Features;
240V (13A)
1600 Max Amps.
Automatic.
Suitable for car bonnet, door and roof panels
Supplied with 1x Spot Inertia hammer, 1x star hold tip, 1x contact shrinking tip, 3x stars and 1x 1.5 earth pad.
20x32x18cm/14kg
Eastwood has a tool that uses a MIG welder to weld a stud to the sheet metal. They also sell a puller attachment that grips the stud.
Every stud welder I have seen requires the studs. I have never seen one that does not require a supply of studs.
One other idea in the same vein is a trick with copper brazing rod and pennies. Braze the penny to the end of the rod. Polish the penny so it is smooth. Coat the polished penny with lead solder. Then sweat solder the brazing rod and penny combination to the sheet metal dent. The brazing will withstand the lower heat of the sweat soldering. Then pull the dent out using the brazing rod. This has the advantage of being able to reuse the rod / penny combination again and again. Simply heat enough to release the sweat soldering bond.
