Thread: Electric tapping machine - video
    Electric tapping machine. By Homelab. 33:23 video:
  2. The Following User Says Thank You to Jon For This Useful Post:
    Neil Jensen (May 22, 2025)
    Jan 2016
    Neil Jensen's Tools
    here is the google translate component names in reverse order
    Chinese → English
    塞打螺栓D6x30xM5x6
    Plug bolt D6x30xM5x6
    Chinese → English
    塞打螺栓D6x20xM5x6
    Plug bolt D6x20xM5x6
    Chinese → English
    快拧螺栓M5x15
    Quick-tightening bolt M5x15
    Chinese → English
    GT12-D08丝锥夹头连接套
    GT12-D08 tap chuck connection sleeve
    Chinese → English
    M10螺母
    M10 nut
    Chinese → English
    气弹簧侧装片
    Gas spring side mounting plate
    Chinese → English
    250-90气缸活塞
    250-90 Cylinder Piston
    Chinese → English
    250-90气弹簧缸体
    250-90 gas spring cylinder
    Chinese → English
    黄铜轴套10X12X8
    Brass bushing 10X12X8
    Chinese → English
    光轴法兰底座D25
    Optical axis flange base D25
    Chinese → English
    双头内螺纹圆柱销D10x20xM6
    Double-ended internal thread cylindrical pin D10x20xM6
    Chinese → English
    黄铜轴套12X16X15
    Brass bushing 12X16X15
    Chinese → English
    黄铜轴套12X16X20
    Brass bushing 12X16X20
    Chinese → English
    黄铜轴套20x25X20
    Brass bushing 20x25X20
    Chinese → English
    光轴止动限位环D20
    Optical axis stop ring D20
    Chinese → English
    小臂铝型材欧标2060L300
    Forearm aluminum profile European standard 2060L300
    Chinese → English
    小臂铝型材欧标2020L300-02_默认<按加工>
    Forearm aluminum profile European standard 2020L300-02_Default <According to processing>
    Chinese → English
    小臂铝型材欧标2020L300-01_默认<按加工>
    Forearm aluminum profile European standard 2020L300-01_Default <According to processing>
    Chinese → English
    光轴立柱D25x300
    Optical axis column D25x300
    Chinese → English
    操作手柄盖
    Operating handle cover
    Chinese → English
    895减速电机防护外壳
    895 gear motor protective housing
    Chinese → English
    2060铝型材弧形端盖
    2060 aluminum profile curved end cap
    Chinese → English
    2060型材端盖
    2060 profile end cap
    Chinese → English
    控制器盒盖
    Controller box cover
    Chinese → English
    895减速电机
    895 reduction motor
    Chinese → English
    波纹管接头AD10-M12x1.5
    Bellows connector AD10-M12x1.5
    Chinese → English
    横滚轴
    Roll axis
    Chinese → English
    D12光轴螺栓滑环(POM)
    D12 Optical Axis Bolt Slip Ring (POM)
    Chinese → English
    D20光轴立柱滑环(POM)
    D20 optical axis column slip ring (POM)
    Chinese → English
    法兰底座安装板
    Flange base mounting plate
    Chinese → English
    横滚轴与电机安装板连接板
    Connecting plate between roll axis and motor mounting plate
    Chinese → English
    俯仰及横滚轴安装件
    Pitch and roll axis mounting
    Chinese → English
    横滚轴轴套端盖
    Roller shaft sleeve end cap
    Chinese → English
    俯仰轴(D10X30)
    Pitch axis (D10X30)
    Chinese → English
    895减速电机安装板(可根据自己电机型号自定义)
    895 reduction motor mounting plate (can be customized according to your own motor model)
    Chinese → English
    小臂与电机俯仰机构连接安装板
    Mounting plate for connecting the forearm and the motor pitch mechanism
    Chinese → English
    2020铝型材端部旋转接头
    2020 Aluminum Profile End Rotary Joint
    Chinese → English
    小臂与D12光轴连接件安装固定板
    Forearm and D12 optical axis connector mounting plate
    Chinese → English
    D12光轴座固定底座
    D12 optical axis fixed base
    Chinese → English
    D12光轴螺栓
    Chinese → English
    小臂与D12光轴连接件
    Connecting parts of forearm and D12 optical axis
    Chinese → English
    大臂与D20光轴连接件
    Connector between big arm and D20 optical ax
