Results 1 to 4 of 4
Thread: Electronic Edge Finder
    mr_modify1's Avatar
    Nov 2021
    mr_modify1's Tools
    I use this mostly on my mill. It was cheaper to make than buy.
  2. The Following User Says Thank You to mr_modify1 For This Useful Post:
    Jon (Dec 17, 2021)
    May 2016
    Don42's Tools
    An LED driven by a 12-volt battery definitely requires a resistor if you want it to last. Most 5mm LEDs are quite happy running at 20 mA. A typical 5mm white LED has a voltage drop of 3.6 volts at 20mA, which indicates a resistor of 420 ohms. 430 ohms is a standard value. 470 would work fine too. Other colors have different voltages but 470 ohms would work OK with any of them.
    A good source for LEDs is
    https://www.ledsupply.com/5mm-leds
    Good selection, reasonable small-quantity pricing, free first-class shipping.
  4. The Following User Says Thank You to Don42 For This Useful Post:
    Christophe Mineau (Dec 18, 2021)
    Thanks mr_modify1! We've added your Electronic Edge Finder to our Electronics category,
    as well as to your builder page: mr_modify1's Homemade Tools. Your receipt:
    mr_modify1's Avatar
    Nov 2021
    mr_modify1's Tools
    Thanks for the info. I know enough about electronics just to get in trouble.
