Ep 01 - 18' Sailboat Build - Strongback
Finally! The time to begin building has arrived and it seems as though it has been a long time coming!
This is the first episode of the 18’ sailboat build and begins with the construction of the strongback. This is necessary to assure a symmetrical boat hull with fair lines, and to hold frames & bulkheads rigidly in position as the longitudinal pieces are installed to tie frames together and install plywood panels which make up the skin of the hull.
Just as a house must have a sturdy foundation before it can be built, the strongback makes up the foundation such that a boat hull can be built.
Here's the video:
https://youtu.be/9FFQkrhNP2o
