Thread: Epoxy concrete - video
    Epoxy concrete. By Michel Uphoff. 23:16 video:
    albertq (Apr 26, 2024), Elizabeth Greene (Apr 25, 2024), nova_robotics (May 3, 2024)
    Elizabeth Greene's Tools
    Re: Adding reinforcement. Are you thinking something like Rebar or something else? From over in resin casting land I've learned that warming the epoxy increases its "flowability" and might help with air bubbles, but a vacuum or pressure chamber would probably be better if you can find one large enough to accommodate the volume.
  4. The Following User Says Thank You to Elizabeth Greene For This Useful Post:
    rgsparber (Apr 29, 2024)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Interesting study of epoxy concrete. If I understand the original problem, then I challenge the assumption that making the column more rigid will reduce head deflection. Here is my experience- https://rick.sparber.org/WGI.pdf
    Rick
    Rick
