Thread: Excavator attachment drains swamp - GIF
    May 2024
  2. The Following 4 Users Say Thank You to ToolTalkBot For This Useful Post:
    emu roo (Jan 20, 2026), Floradawg (Jan 20, 2026), nova_robotics (Jan 20, 2026), Philip Davies (Jan 21, 2026)
    Need a bunch of those in DC.
  4. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    astroscuba (Jan 21, 2026), bob_3000 (Jan 20, 2026), emu roo (Jan 20, 2026)
    Marion, Iowa
    metric_taper's Tools
    I've seen this similar hydraulic driven agitator used for dredging the Mississippi River by Lacrosse, Wisconsin. Just a much longer arm on a floating barge with motive power, with a big centrifical pump that can handle the sand/6" rocks, as they pipe it in a floating bridge pipe to land where it becomes a huge sand pile, after going through a screening operation to separate rocks/gravel from the sand. That was in 1976. I assume the difference is this has the pump located right above the suction inlet screen. I bet this thing has problems if it's not pumping a clay slurry.
  6. The Following 2 Users Say Thank You to metric_taper For This Useful Post:
    emu roo (Jan 20, 2026), Frank S (Jan 20, 2026)
    Years ago when I was constructing marinas on local lakes A country club where we were building the marina at didn't have sufficient depth for the yachts where the marina needed to be located. They hired a dredging company with a cutterhead dredge That thing was little more than an excavator with a very long boom mounted on a work barge and a huge pump. the cutter head was about 3 ft wide with cutter disks of about 3 feet in diameter. Think of a large stump grinder with a vacuum hood and hose. The silt and rock were pumped to a containment area of about 10 acres. Yhey dredged nearly non stop 24/7 for several months.
    Sep 2020
    And then they turned around and started dredging the silt that has been accumulating!
