Results 1 to 8 of 8
Thread: Excavator chimney demolition gone wrong - GIF
    Excavator chimney demolition gone wrong.
    Excavator building demolition gone wrong - GIF
    Perfect controlled demolition of twin chimneys - video
    Demolished water tank falls on excavator - GIF
  2. The Following 12 Users Say Thank You to Jon For This Useful Post:
    baja (Aug 27, 2019), carloski (Jun 25, 2022), clydeman (Jul 4, 2024), emu roo (Jun 2, 2026), EnginePaul (Aug 26, 2019), high-side (Aug 31, 2019), Midwestern640 (Aug 26, 2019), Miloslav (Aug 26, 2019), Ralphxyz (Jun 2, 2026), Seedtick (Aug 26, 2019), Sleykin (Jun 18, 2022), Tule (Aug 27, 2019)
    The operator was clearly trying his best to get as far away from the silo coming down as possible.
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    What did he friggen think was going to happen?
    When you cut a wedge out of a tree that’s the way it’s going to fall. Same thing with a concrete silo.
  6. The Following User Says Thank You to Radioman For This Useful Post:
    Jul 2019
    But did he survive that???
  8. The Following 2 Users Say Thank You to Scrounga For This Useful Post:
    cmarlow (Dec 29, 2021), emu roo (Jun 2, 2026)
    Quote Originally Posted by Scrounga View Post
    I imagine he would have as long as there was a rock shield in front of the windscreen glass
    If he wasn't asphyxiated from the dust.
  10. The Following User Says Thank You to Frank S For This Useful Post:
    C Tucker's Avatar
    Jan 2019
    I have help drop a cement block silo and that is NOT how ya do it. We knock a couple holes in the bottom just less than half way around from each other. Ran a cable thru the holes and looped it back to a tractor. The cable was long enough to keep the tractor out of the fall area and you just drive away, pulling the support out from under half the silo. It dropped right where we wanted it to.
  12. The Following 4 Users Say Thank You to C Tucker For This Useful Post:
    emu roo (Jun 2, 2026), Ralphxyz (Jul 6, 2024), that_other_guy (Oct 4, 2021), wesser1 (Jul 4, 2024)
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    For better or worse, evolution works.
    I hope no innocent bystanders were hurt. And I guess I hope the driver was OK too.
    Paul A.
  14. The Following User Says Thank You to Paul Alciatore For This Useful Post:
    May 2017
    Lucky his cabin was on the left side of the machine. They should be fiited with stand-alone
    Face air'supply.
    Probably not.
  16. The Following User Says Thank You to Buster Gonad For This Useful Post:
