Thanks for the reply
The generator will sit inside a heavy duty metal cage. with around 3-4" away from the internal walls of the box which will suround it, access to start the generator will be from outside the shed via a side door, which will left open when its running anyway.
The fuel tank will be accessable from the inside & the pull start if needed via a hinged lid, and also to remove the generator if need be.
PS I'll go into more detail when answering the other replies
