Exhaust on a petrol generator
Hi..........Iam wanting to put a petrol, electric start, low noise generator in a shed with access to run it from the outside and seal it inside (a shed inside a shed), but with a lid on the inside for access, the generator will be housed in a heavy duty cage, as we have a few tea leaves around.
Im looking for advice on the following, is it possible to do? and safe?
1) can the exhaust pipe be extended to take the fumes outside, when inside the workshop/shed via a small fan
2) put a pipe on the air intake from the outside, via a small fan
3) how to keep the any noise level down, when inside the workshop/shed
cheers
Quote:
Originally Posted by
rlloyd
cheers
I would recommend that you put your small shed with the generator in it outside your big shed for safety concerns. A small exhaust leak in a small enclosed area like a shed can be deadly. But to answer your question, no fans needed. make sure the exhaust is piped with rigged threaded pipe and use sealant on the threads and run the pipe at least one foot past the outside of the shed. make sure the intake pipe is at least twice as large as your intake at the motor and you must have an air filter. Your biggest problem is going to be the heat from the generator itself. Small air cooled motors will overheat quickly in an enclosed environment.
