Results 1 to 8 of 8
Thread: Expanding arbor
    Supporting Member EclecticNeophyte's Avatar
    Apr 2013
    TriCities, WA.
    EclecticNeophyte's Tools
    Expanding arbor
    Nothing fancy here... Just cold rolled mild steel round bar, drilled, threaded for 1/4 - 20, then cut with slitting saw. Holds like a dream. I was wondering how to make a tapered plug, then 'discovered' some Swagelok fittings in my junk box... The stainless ferule worked great near the head of a common 1/4 - 20 x 1 1/2" hex head bolt. The round bar is turned to fit the I.D. of the part I wanted to hold. In this case, about 9/16".
    The arbor was first drilled (#6), then tapped, then opened up with a F drill to facilitate the bolt shank and thin the wall a bit. It was then cut using a slitting saw in the mill, and finished using my 4 x 6 HF horizontal bandsaw...then de-burred.
    -EN
  2. The Following 6 Users Say Thank You to EclecticNeophyte For This Useful Post:
    bruce.desertrat (Mar 3, 2021), elk-a-holic (Mar 2, 2021), Jon (Mar 1, 2021), nova_robotics (Mar 2, 2021), Ralphxyz (Mar 3, 2021), rarmintrout (Mar 3, 2021)
    Thanks EclecticNeophyte! We've added your Expanding Arbor to our Metalworking category,
    as well as to your builder page: EclecticNeophyte's Homemade Tools. Your receipt:
    bruce.desertrat's Tools
    That Swagelok tip is a great find!!
  5. The Following User Says Thank You to bruce.desertrat For This Useful Post:
    EclecticNeophyte (Mar 3, 2021)
    Another "out of the parts drawer" way to do this is to tap the arbor with a (tapered) pipe tap and then use a tapered pipe plug to expand it.
    Home Shop Freeware
  7. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    DIYSwede (Mar 3, 2021), EclecticNeophyte (Mar 3, 2021)
    Apr 2013
    TriCities, WA.
    The pipe tap/plug trick would probably allow for greater range of expansion as well.
    The 1/4" Swagelok ferule has far shorter and more aggressive taper than I desired, but a very quick solution that worked. I may eventually try to turn something with a much more gradual taper, that would expand (and support) a greater length of the arbor... Lots of ways to do this better than I did.
    -EN
    Apr 2013
    TriCities, WA.
    Quote Originally Posted by bruce.desertrat View Post
    A lucky find on my part (no pun intended).
  10. #7
    Dec 2016
    Ralphxyz's Tools
    What is that in your last picture held in the lathe chuck?
    Ralph
  11. #8
    Apr 2013
    TriCities, WA.
    Ralph
    It's the reason I needed...ok, WANTED the arbor... When it's finished, and if all goes according to plan, it will be a part of an item like this...
