Results 1 to 8 of 8
Thread: Extension Cable Reel Making - DIY Video
    GreenSaw
    RCTURKA's Avatar
    Feb 2019
    RCTURKA's Tools
    Thumbs up Extension Cable Reel Making - DIY Video
    Hi, my new tool.
  2. The Following 3 Users Say Thank You to RCTURKA For This Useful Post:
    Jon (Feb 10, 2021), terryjs (Feb 8, 2021), Toolmaker51 (Feb 15, 2021)
    Oct 2020
    Love the job.
    Remember to be careful using reels with anything that draws a bit of current though
  4. The Following User Says Thank You to terryjs For This Useful Post:
    NortonDommi (Feb 16, 2021)
    Thanks RCTURKA! We've added your Extension Cord Reel to our Extension Cords category,
    as well as to your builder page: RCTURKA's Homemade Tools. Your receipt:
    Quote Originally Posted by terryjs View Post
    Love the job.
    Did a sewer snake entangle an extension, or coil of wire create heat by induction?
    jdurand's Tools
    ah yes, derate a LOT if still on the reel, used in the sun, or you're just accident prone
  8. The Following User Says Thank You to jdurand For This Useful Post:
    Alarming. I wondered which was the signal; smell, smoke, flames, sparks?
    North Island, New Zealand.
    NortonDommi's Tools
    "Remember to be careful using reels with anything that draws a bit of current though" - I got a major dressing down from an electrical design engineer I know when he saw me using a coiled up extension cord with only a few feet run out. Something I had done for many years without a thought. Induction apparently causes a lot of overheating, fires and shorts, something I'd not heard about and nobody had ever pointed out.
    Toolmaker51 it may have been when the tool stopped working?
  11. The Following User Says Thank You to NortonDommi For This Useful Post:
    Toolmaker51 (Feb 16, 2021)
  12. #8
    jdurand's Tools
    A big part is just heat dissipation. Wires are rated to run in free air.
    So, under USA code:
    Derate if more than a few wires in a raceway (conduit/wire tube).
    Derate if in a warm area.
    Derate if load is over 80% duty cycle.
    Derate if inspector is having a bad day.
    So, when we installed our off-grid solar here I had to use rigid conduit (water pipe) but since it goes through the attic to the roof the wires had to be derated 20% for heat. Solar panels are assumed to be 100% duty cycle, derate another 20%.
    Also the ground wire can not have any junctions from the stake to the battery controller. I just slipped by not having to use a ground wire the same size as the battery cables, that would have HURT my wallet!
  13. The Following User Says Thank You to jdurand For This Useful Post:
