Thread: Fabricated shaft for ring roller.
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    This is a fabricated shaft for a ring roller I am making.
    This method meant I could use 12mm stock diameter material for the smaller diameter of the shaft which fits the bearings rather than machining from solid stock. The larger end was left oversize on all diameters and once screwed and Loctite together was machined true to the smaller diameter. This method saves a lot of time and material removal.
    Two parts ready to be loctited together
    Loctite retainer 601
    Mole grips to ensure the two components are locked tightly together
    Turning with a left hand lathe tool
    Finished turned shaft
    Shafted test fitted to housing
    Fitted to ring roller frame assembly
    Thank you for viewing
    The Home Engineer
    Attached Thumbnails Attached Thumbnails Fabricated shaft for ring roller.-img_0914.jpg
  2. The Following 3 Users Say Thank You to thehomeengineer For This Useful Post:
    Frank S (Mar 3, 2018), NickP (Mar 4, 2018), Seedtick (Mar 4, 2018)
    Thanks thehomeengineer! We've added your Ring Roller Shaft to our Machining category,
