Results 1 to 4 of 4
Thread: Face plate for lathe
  1. #3
    Jan 2016
    lazarus's Tools
    Sorry about the lack of info. Yes it is a 10lb cast iron weight that someone discarded. I ground the letters off and turned it straight in my brake lathe. The hole was too small for my 6" 3jaw so I reference marked it for the chuck jaw holes. Drill press got me 3 holes for the chuck jaw to fit snug. I put it in the 3 jaw as shown and bored center, turned face and outer edge. I put reference lines on it to help center(rough) odd parts and such. I marked it to #1 jaw and can remove it and replace it as needed without much work truing. Then I flipped it and cleaned up the back edges. I needed it because I didn't have a 4 jaw but one became available and I didn't use it. This will probably be used as a drive plate now, but it could get holes drilled and tapped for parts and clamps. I will use it when the necessity bug bites me.
    I hope this clears up the questions and helps if someone needs one. This is not intended for heavy work, but a dedicated back plate could change that.
    Ben
  2. The Following 2 Users Say Thank You to lazarus For This Useful Post:
    Paul Jones (Jun 1, 2016), PJs (Jun 2, 2016)
