Failed bearing melts housing.
Assembling a double row bearing - GIF
Ball bearing dismantling - GIF
Installing a large bearing - GIF
Internal bearing puller - GIF
Knife from rusty bearing - video
emu roo (Jan 6, 2026), nova_robotics (Jan 7, 2026)
Wonder why it is that people's first instinct seems to be to stand there for 10 seconds filming something which judging by the color of the shaft could be only seconds away from catastrophic failure, instead of hitting the emergency stop button that is most likely located on the front of that yellow box then start filming as the machine cycles to a stop.
emu roo (Jan 6, 2026), Karl_H (Jan 6, 2026), KustomsbyKent (Jan 6, 2026)
It would if the shaft were to break then there would be a lot more to worry about. As bad as the condition was right then as long as the shaft is not broken once it cooled and the bearing was removed the shaft could be built up and machined back to specs possibly without having to remove it with a portable journal lathe
https://mm-source.com/strikertm-port...nal-lathe.html
Not one like in the link but something like my portable boring bar set up except with a cutter facing inside mounted on a hollow cylinder index beringed from the undamaged portion of the shaft closer to the belt roller
No, it didn't but the videographer couldn't have known when it would. Perhaps that was their hopes. To video what happens when the shaft broke to increase their hit count. instead to attempting to prevent more damage costing the company a lot more money and down time.
There is another scenario whoever was shooting the video may have alerted someone to shut the machine down and remained there videoing the failed bearing while a supervisor was initializing shut down. We can't know for sure there was an "E" button located on the face of the yellow box, but that is usually why boxes like that exist.
