Hi Petej,
I fully agree with all the other comments. An after market fence system such as the Biesmeyer is the way to go, although not cheap! One possible solution is to use an aluminium or mild steel tube (round or square to suit your fence fitting) in place of the existing bar. This is the system used on my Scheppach TS 2500 saw and has the advantage that the fence is mounted to the slide with 4 adjustable bolts to enable spot-on setting up. Hope this helps.
Sprog
