Results 1 to 6 of 6
Thread: Fixing a broken PVC pipe inside a wall - GIF
    May 2024
    Moby Duck (May 17, 2024), nova_robotics (May 7, 2024)
    hemmjo's Tools
    Nice idea, BUT, the pipe got broken off once. It is going to get broken off again. That repair will make the next repair more difficult. I think I would have made that "split adapter long enough to slide a lot further inside and NOT glue it into the wall. That way, next time it gets broken, slide out the old piece insert a new one.
    Aug 2021
    Cape Town SA
    albertq's Tools
    If the inserted pipe is not glued in, there is a very good chance of leaking. Better to install some external protection against whatever caused it to break.
    hemmjo's Tools
    Quote Originally Posted by albertq View Post
    It appears to be a drain pipe. The only time it has water in it is when it rains and everything is wet anyway.
  6. The Following User Says Thank You to hemmjo For This Useful Post:
    albertq (May 8, 2024)
    Aug 2012
    Australia
    desbromilow's Tools
    since this repair adds a small constriction in the pipe diameter (internal) - is that an issue? if it was sewage pipe, the internal piece would need chamfering to be less of a hangup point?
    There is also the possibility the pipe is a vent pipe
