Results 1 to 10 of 12
Thread: Fixing a worn screw hole using a paper clip - GIF
    Fixing a worn screw hole using a paper clip.
    Marking door strike plate location - GIF
    Sanding a sagging door - GIF
    Self-closing hinge - GIF
    Hinge tweaking tool - photo
    Fixing a sagging door - GIF
  2. The Following 7 Users Say Thank You to Altair For This Useful Post:
    durrelltn (Feb 7, 2022), Floradawg (Feb 8, 2022), Inner (Feb 7, 2022), Moby Duck (Feb 11, 2022), nova_robotics (Feb 7, 2022), Philip Davies (Feb 13, 2022), Toolmaker51 (Feb 6, 2022)
    ! So much for toothpicks, wooden match sticks, or chop sticks.
    If you can fine one a bobby pin works well too, because they already have a natural thread shape in the ridges plus since there is more mass due to width, they will take up more space in a stripped-out hole
  6. The Following 4 Users Say Thank You to Frank S For This Useful Post:
    durrelltn (Feb 7, 2022), Inner (Feb 7, 2022), Moby Duck (Feb 11, 2022), Toolmaker51 (Feb 6, 2022)
    Marion, Iowa
    metric_taper's Tools
    I was going to make that same comment about using a toothpick or match.
    Looks like the real problem was using a power tool, an stripping out the wood threads.
  8. The Following User Says Thank You to metric_taper For This Useful Post:
    Drew1966 (Feb 14, 2022)
    Almost; looks a problem is powerful tools, the real problem, that being sold as 'wood'.
    My house, built 1901, still takes work to start and enter a screw.
  10. #6
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Useful tip. But that screw looks shorter than the ones normally used.
  11. #7
    Short screws are common here, in kits of new hardware. I replace with longer, to fully penetrate casing; exterior doors longer yet into the framing.
    Exterior and basement doors also get pinned; pressing a spring pin into the fixed side, a clearance hole on the other. With a double cylinder deadbolt, door becomes difficult to get out; even with hinge pins removed.
    Last edited by Toolmaker51; Feb 13, 2022 at 10:54 AM. Reason: added pic by addled user
  12. The Following 5 Users Say Thank You to Toolmaker51 For This Useful Post:
    Jon (Feb 14, 2022), metric_taper (Feb 14, 2022), mwmkravchenko (Feb 15, 2022), Philip Davies (Feb 13, 2022), that_other_guy (Feb 20, 2022)
  13. #8
    Perth Ontario Canada
    That's good practice. Cuz it's what the installers do!
    I have installed literally near a thousand doors. One long screw each on the hinges is usually enough. But you will have to increase the size of the countersink on the hinges for this to work perfectly. On your hinges I think you got away with it. But conventional hinges you have to do the counter bore to accommodate the number 10 screws. I don't use number 8's not enough meat on the shanks.
  14. The Following 2 Users Say Thank You to mwmkravchenko For This Useful Post:
    Philip Davies (Feb 16, 2022), Toolmaker51 (Feb 15, 2022)
  15. #9
    Dec 2015
    Reading, Berks, UK
    Quote Originally Posted by mwmkravchenko View Post
    Wally Faulkner, who taught us carpentry at Reading Tech, told us more than once, “When you’ve shifted a ton of nails, you can call yourself a carpenter!” So, by extension, I would say that having “ shifted” 1000 doors, you are unquestionably ranked as a second-fix carpenter!
  16. The Following User Says Thank You to Philip Davies For This Useful Post:
    mwmkravchenko (Feb 16, 2022)
  17. #10
    Shifted?
    From box to framing? Pulled and reset? Bent them like a transmission lever?
  18. The Following User Says Thank You to Toolmaker51 For This Useful Post:
