Flat sanding cawl
In luthery work, for the purpose of leveling the frets of a fingerboard, you need a dead flat sanding cawl.
Here is how to make one out of wood and glass.
I first shape a wooden handle block, planned as flat as possible.
Then I cut with a standard glass cutter three layers of the same size out of a scrap piece of window glass, maybe 3mm thick.
All these, glued together using CA glue (works very well on glass)
After the glue has cured, the edges are smoothed using a dremel and a diamond wheel.
Eventually, I have stuck a sheet of 1000 grit sandpaper using double side tape.
https://www.labellenote.fr/file/home...gCawl_0001.jpg
https://www.labellenote.fr/file/home...gCawl_0002.jpg
https://www.labellenote.fr/file/home...gCawl_0003.jpg
https://www.labellenote.fr/file/home...gCawl_0004.jpg
https://www.labellenote.fr/file/home...gCawl_0005.jpg
Thanks Christophe Mineau! We've added your Flat Sanding Caul to our Luthiery category,
as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-flat-sanding-caul">
<img src="/uploads/231198/homemade-flat-sanding-cawl.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-flat-sanding-caul">Flat Sanding Caul</a>
<span> by <a href="https://www.homemadetools.net/builder/Christophe+Mineau">Christophe Mineau</a></span>
</div>
<div class="tags">tags:
<a href='https://www.homemadetools.net/tag/sanding-block'>sanding block</a> </div>
</div>
</div>
</div>
Very cool, Christophe. This is something I can use in my guitar making and repair work. I note your wooden pattern makers vise in the photo.
Thanks Joe. Yes, I think I have showed already this one, yes it's here :
https://www.homemadetools.net/forum/...0908#post12947
I like this vise, and the wooden build doesn't make it less usable than the cast iron version. It's been maybe 12 years I have built it I think, still in use.
Maybe , sooner or later I'll have to redo the handle of the crank witch pivot is maybe too far backward from the bearing that supports the screw.
Laminated glass! Nice touch. I made something like this 30 years ago when i started doing piano gloss black type finishing. It is a very effective way to make a flat area very flat!
