Results 1 to 5 of 5
Thread: Flint striker
    Dec 2015
    Reading, Berks, UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Philip Davies's Tools
    Flint striker
    [ATTACH=CONFIG]32203[/ATTACH
    It seems that nobody has posted one of these before on this site.
    I was surprised when a search revealed no results, because, although obsolete, itís quite a popular novelty item( like candle holders-which I donít make either)
    I was mainly sanding things in the workshop, but had the fire going to keep warm, so using the latent heat, I would tap this into shape gradually, over the course of three days! So I did not use the air pump. As the fire diminishes, I shovel the glowing embers into a lidded steel box, and thatís my charcoal for when I want a white/yellow heat.
    Itís made from a worn file. Although ergonomic, I do not care for the shape much, itís a bit of an abortion, if youíll pardon the allusion.
  2. The Following 2 Users Say Thank You to Philip Davies For This Useful Post:
    Jon (11-28-2019), Paul Jones (11-22-2019)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Philip Davies! We've added your Flint Striker to our Forging and Casting category,
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    bruce.desertrat's Tools
    The shape is a little...lumpy-ish, but that gives it some handmade charm. I should someday see if my mom still has the wrought door-knocker I made in my HS welding/forging class...THAT was only-a-mother-could-love-it ugly :-)
  5. The Following User Says Thank You to bruce.desertrat For This Useful Post:
    Philip Davies (11-22-2019)
    Dec 2015
    Reading, Berks, UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree that the lines are not quite as sweet as a French curve drawing aid, or did you mean that there were hammer marks visible? I think that for craft fairs it is an advantage that the forging is a bit rough, so that it is obviously hand-made, although technically, smithwork should not be “lumpy”!
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I meant the lines, not the hammer work...'not as sweet as a french curve' is a better description.
    Post your reply!
    Join 42,532 of us and get 200+ tool plans, tool eBooks, build guides, and much more.
    eBooks for Supporters
  8. The Following User Says Thank You to bruce.desertrat For This Useful Post:
