Results 1 to 7 of 7
Thread: Flow friction drilling - GIF
  2. The Following 10 Users Say Thank You to Jon For This Useful Post:
    Andyt (Jan 2, 2020), baja (Jan 2, 2020), emu roo (Feb 15, 2025), jimfols (Jan 1, 2020), n9dug (Jan 1, 2020), Quinton 357 (Jan 3, 2020), Ralphxyz (Feb 16, 2025), Seedtick (Jan 1, 2020), Tonyg (Jan 2, 2020), uv8452 (Feb 15, 2025)
    now the hole is thick enough for threading no need for thread inserts
    Dec 2016
    Ralphxyz's Tools
    I wonder what the rpm is? And the material?
    Sep 2015
    Ontario Calif USA
    This is from a AvE vidjeo that explains more about the tool. Very interesting.
    I cannot post the link because he uses bad words and some might be offended.
    But it is a worthwhile video. If you can't find it contact me off list.
    Jim
    Supporting Member high-side's Avatar
    Jun 2018
    Quote Originally Posted by jimfols View Post
    I think the value of the information outweighs the risk of being offended.
    Those that are offended that easily should skip following the link.
    Pat
    Dec 2016
    Ralphxyz's Tools
    Well here is a link from a manufacturer for a Formdrill. No offensive words are spoken.
  8. The Following User Says Thank You to Ralphxyz For This Useful Post:
    high-side (Jan 2, 2020)
  9. #7
    Oct 2019
    Germany
    uv8452's Tools
    It looked simple: 20 years ago I experimented with homemade friction drill bits as the commercial ones were way too expensive.
    We ground similar shaped tungsten bits (ø5 and ø7) - neither quick nor easy. We needed a rigid drill press and a strong worker. Result: Very little material flow.
    It improved when we gave the cone 3 tiny longitudial flats - i.e. a polygon cross section. The (absurd) final solution was to drill a ø3 pilot hole and then widen it with friction drilling (we needed the extra 'thickness' to cut threads). Cut! Avoid threads in sheet metal.
