In the follow-up video, we finish our conversion of the log splitter-turned forging press, and we put it to use and abuse. Please subscribe to see more projects!
https://youtu.be/pA5fJfcpY2Y
Thanks AirborneProductions! We've added your Forging Press to our Knife Making category,
as well as to your builder page: AirborneProductions's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-forging-press-4"> <img src="/uploads/232528/homemade-forging-press-4.png"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-forging-press-4">Forging Press</a> <span> by <a href="https://www.homemadetools.net/builder/AirborneProductions">AirborneProductions</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/press'>press</a>, <a href='https://www.homemadetools.net/tag/forging'>forging</a> </div> </div> </div> </div>
I have exactly the same log splitter for exactly the same purpose. I was however about to go down a bigger worm hole to achieve what you have. My plans have just been changed to this simple idea which essentially achieves the same outcome. Thank you!
There are lots of uses for log splitters besides their intended usage. I have seen can crushers, iron workers, apple cider presses, bearing presses, and I even had a friend that used his to remove his finger tip by accident of course. They are a much overlooked machine for modifying for another purpose.
