Results 1 to 10 of 19
Thread: foundry work - aluminum pulley
    Supporting Member celsoari's Avatar
    Jan 2018
    Brazil
    celsoari's Tools
    Step by step how I build an aluminum pulley
    Greetings from Brazil
    Celso Ari
  2. The Following 22 Users Say Thank You to celsoari For This Useful Post:
    baja (Feb 4, 2020), BIGGUYRALPH (Feb 6, 2020), bigtrev8xl (Feb 4, 2020), Carnel (Feb 4, 2020), Crusty (Feb 1, 2020), DIYSwede (Feb 5, 2020), high-side (Feb 3, 2020), IAMSatisfied (Feb 3, 2020), Jon (Feb 6, 2020), Karl_H (Feb 4, 2020), lassab999 (Nov 3, 2022), LucasC (Feb 10, 2020), mhfcell420 (Mar 12, 2021), neilbourjaily (Feb 3, 2020), Ralphxyz (Feb 9, 2024), Resident114 (May 24, 2023), rgsparber (Feb 12, 2020), rlm98253 (May 24, 2023), Shanty (Feb 9, 2020), that_other_guy (Nov 2, 2022), thehomeengineer (Feb 4, 2020), Tule (Feb 10, 2020)
    Thanks celsoari! We've added your Casting Mold to our Forging and Casting category,
    as well as to your builder page: celsoari's Homemade Tools. Your receipt:
  4. The Following 3 Users Say Thank You to DIYer For This Useful Post:
    celsoari (Feb 2, 2020), ChasT (Feb 3, 2020), emu roo (Aug 28, 2025)
    Supporting Member IAMSatisfied's Avatar
    Apr 2017
    The desolate ranch country of Northeastern corner of New Mexico, USA
    IAMSatisfied's Tools
    I always appreciate your contributions, Celso!
  6. The Following 2 Users Say Thank You to IAMSatisfied For This Useful Post:
    celsoari (Feb 5, 2020), emu roo (Aug 28, 2025)
    JeffEck's Avatar
    Jan 2017
    Kansas
    JeffEck's Tools
    curious
    Is it stronger to case the block vs using a round extrusion that is the same diameter? I am a novice and have no idea, I can get just about any shape in any size I want at a local store, cusious why the choice is to cast the block vs cust it off the end of a round bar? Your work is beautiful, at times I really want to learn to cast as well as you! -jeff
    Dry Gulch, Tx
    Crusty's Tools
    Go price some aluminum in that diameter and you'll learn why he cast his own from scraps. It's hideously expensive if you can even find it in that short of a length.
  9. The Following 2 Users Say Thank You to Crusty For This Useful Post:
    celsoari (Feb 5, 2020), Ralphxyz (Feb 9, 2024)
  10. #6
    JeffEck's Avatar
    Jan 2017
    Kansas
    JeffEck's Tools
    When I'm not buying full stick for jobs I goto The Yard Store, they price aluminum at $2.5/lb down to $1.5/lb for cut offs. I looked at an online supplier that I have used once, 3 inches of 8" 6061 round was $58. About a year ago I purchased 3" of 6" round and 5" of 4" round, bill at the yard store was $60. (I was building a base for a ball turning attachment for my 14" Rockwell lathe) I think they sell online. Is that is more expensive than casting, considering the time of the guy working? Thanks for responding, can't learn anything in a vacuum..
  11. The Following 2 Users Say Thank You to JeffEck For This Useful Post:
  12. #7
    Dry Gulch, Tx
    Crusty's Tools
    Those are sweet prices but casting is nearly free if you're scrounging from the scrap pile and not putting a dollar value on your time.
    It doesn't take a lot in the way of equipment and the learning curve isn't steep with aluminum casting, and it puts a world of new possibilities into your hands once you're set up because you can quickly produce aluminum castings that with some finish machining can become useful things. Dave Gingery produced a whole series of books detailing building a machine shop cheaply (with a metal shaper even) made from castings using a charcoal furnace and wooden patterns in green sand molds. These days there's even folks making castings from Styrofoam patterns coated in plaster of Paris in a variation of the lost wax process which is even easier than green sand molding.
    It's fun melting metal and opening the flask after a successful pour can be a real hoot.
  13. The Following 2 Users Say Thank You to Crusty For This Useful Post:
  14. #8
    Sep 2013
    Karl_H's Tools
    Quote Originally Posted by JeffEck View Post
    Is it stronger to cast the block vs using a round extrusion that is the same diameter?
    Good case made for cost. Does anyone know about strength?
  15. The Following 2 Users Say Thank You to Karl_H For This Useful Post:
  16. #9
    Stockholm, Sweden...
    DIYSwede's Tools
    For me personally, I'm into casting mostly for cheapness, but also to get the stock sizes and forms I need.
    2nd: No pure Al (like ladders, extrusions, beer cans) in my melts, only stuff that has been cast before:
    My favorite is the AlSi10Cu3Fe die-casting alloy ("383"-ish), which I can get for free from discarded office furniture stands at work.
    This alloy has excellent corrosion and casting properties (even in sand casts), machines nicely with short swarf,
    but the Si content makes it rougher on HSS than pure Al. I've got abt 100 lbs of those cut-ups to melt.
    Cannot be aged/ heat treated (though some research reports claim to have managed that, too) nor anodized.
    Properties: 80-100-ish Brinell hardness, 45-50 ksi tensile strength and a mere 1000-1100 F melting point. Cold ages in a month.
    This alloy could also be combined with ZA-8 Zamak to get a lo-creep bearing alloy with better properties than bronze
    at very high bearing pressures and lo rpms:
    Metallurgy for DIY:ers - Meccano Gallery
    Just my 2 cents
    Johan
  17. The Following 4 Users Say Thank You to DIYSwede For This Useful Post:
    celsoari (Feb 5, 2020), emu roo (Aug 28, 2025), that_other_guy (Nov 3, 2022), Tule (Feb 10, 2020)
  18. #10
    Jan 2018
    Brazil
    celsoari's Tools
    Quote Originally Posted by IAMSatisfied View Post
    Thanks Bro
