Results 1 to 10 of 17
Thread: Free Hand and Ball Turning Tool
    Apr 2017
    UK
    editor@glue-it.com's Tools
    This has been quite a simple, but rewarding build. The free hand turning tool has been designed for the Warco WM240B, but the idea could be adapted for most lathes. This would even work on a wood lathe for turning precise wooden balls or curves.
    Also, here is a close up of the free hand turning tool
  2. The Following 16 Users Say Thank You to editor@glue-it.com For This Useful Post:
    bruce.desertrat (Dec 11, 2021), Bullet500 (Dec 13, 2021), Dimsa (Dec 6, 2021), DIYSwede (Dec 5, 2021), emu roo (Dec 7, 2021), Home-PC (Dec 7, 2021), Inner (Dec 10, 2021), johncg (Dec 7, 2021), Jon (Dec 6, 2021), lassab999 (Dec 7, 2021), mwmkravchenko (Dec 8, 2021), nova_robotics (Dec 6, 2021), Ralphxyz (Dec 8, 2021), SculptyWorks (Dec 10, 2021), that_other_guy (Dec 10, 2021), Toolmaker51 (Dec 11, 2021)
    Stockholm, Sweden...
    DIYSwede's Tools
    Nicely designed and cleverly executed, Nigel!
    You could also add a profile / tracer attachment as these guys offer for just under 400 bucks:
    https://www.eccentricengineering.com...turning-system
    All the best!
    Cheers
    Johan
  4. The Following 2 Users Say Thank You to DIYSwede For This Useful Post:
    editor@glue-it.com (Dec 6, 2021), Home-PC (Dec 7, 2021)
    Thanks editor@glue-it.com! We've added your Freehand Ball Turning Tool to our Machining category,
    as well as to your builder page: editor@glue-it.com's Homemade Tools. Your receipt:
    Apr 2017
    UK
    All the best!
    Cheers
    Johan
    that's cool, would be great from creating brass parts like the chimney cap on the traction engine, thanks
    Supporting Member gatz's Avatar
    gatz's Tools
    good one !
  8. The Following User Says Thank You to gatz For This Useful Post:
    editor@glue-it.com (Dec 7, 2021)
    Supporting Member bob1275's Avatar
    Aug 2017
    Devon, UK
    Good idea, what bit are you using to engrave slots in brass?
  10. #7
    Jan 2017
    Ball turner?
    Quote Originally Posted by editor@glue-it.com View Post
    Not so much a BALL TURNER as an end-radiusing tool. I wouldn't like to be holding the tool if I made a mistake and the cutting tool dug into the brass!
  11. #8
    Apr 2017
    UK
    Quote Originally Posted by bob1275 View Post
    Hi Bob, hopefully this video and a quick page on the engraving bits will help:
  12. #9
    Aug 2017
    Devon, UK
    Many thanks
  13. #10
    Maybe I'm being a bit over cautious in my thoughts but since this holder is not mounted down, I can't help but wonder if the base diameter to the height of the cutter ratio is sufficient to prevent vibration or the cutter gouging in too deep, I'll admit to having never ran a lathe with a smaller swing than 10" and most of my work involves a lot heavier turning.
