Results 1 to 10 of 18
Thread: Fuel tank welding fire - GIF
    Altair's Avatar
  2. The Following 5 Users Say Thank You to Altair For This Useful Post:
    carloski (Oct 17, 2022), jimfols (Jul 15, 2021), NortonDommi (Jul 15, 2021), nova_robotics (Jul 15, 2021), Scotsman Hosie (Jul 22, 2021)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    I thought 'At least it is not still on the vehicle' and then the fuel started leaking! Welding a tank isn't hard or dangerous provided a few precautions are taken.
    Lake Tahoe
    IntheGroove's Tools
    And always wear your finest welding attire, shorts and crocs...
    Aug 2012
    Australia
    desbromilow's Tools
    using the pressure blaster as a fire suppression tool was a BIG mistake, all it did was push the fuel around the scene and make the problem bigger. There is a reason why you never use water in a fuel fire, and spreading it around is the main reason.
    most pressure blasters would introduce entrained air, plus kick the fuel around enough to have the effect of fanning the fire, rather than smothering it.
    Sep 2015
    Ontario Calif USA
    I thought Slapstick Comedy was all gone.
    Jim
    batchit's Avatar
    Apr 2021
    Another entrant in the 2021 Darwin Awards.
  8. The Following User Says Thank You to batchit For This Useful Post:
    Ralphxyz (Jul 21, 2021)
  9. #7
    Mar 2020
    Welding fuel tanks is not a hastily shoddy work, it is extremely dangerous process!
  10. #8
    Dec 2015
    If you fill it with water first there are no fumes to explode.
  11. #9
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by bill1943 View Post
    I think in this case there was considerably more than fumes in there - ie you can see the liquid fuel being pushed around by the water blaster.
    I do know people who weld on tanks FULL of diesel, but that is because they control the amount of vapour, and the fuel air mix that results. Too rich is just as safe as too lean in most circumstances, but you've got to really know what you're doing to pull that off.
  12. #10
    Mar 2018
    The definition of "A comedy of errors"! Remember: Always lift with your back, Always close your eyes when crossing the street, never wear a shirt when welding and Always use water when extinguishing a fuel spill!
