Keep your workplace clean!
https://youtu.be/2cKaAkue7Vk
Never had a problem before!
How do you nominate someone for a Darwin Award?
Incredible
Hopefully it’s diesel - but not likely. I surely wouldn’t have been sticking around to get the video.
Ever cross anybody's mind that it could be water? Just because it LOOKS like a fuel hose does not make it so.
Note that the hose is connected to the pump! Maybe it's fueling water-powered cars... :lol:
It's water. The way it behaves when it hits the ground would indicate that. Gasoline "soaks" into the surface and spreads. You would also see indications of the fumes / evaporation disturbing the image just above the surface of the concrete. Just because the hose goes to a metal stand some call a "gas pump" doesn't mean it picks up fuel from the tanks below. Not being able to see the plumbing, there's no telling what feeds the nozzle. Many have stated it can't be unless cars run on water. What about radiators? Those need water on occasion don't they? Maybe he had it installed specifically to do what the video shows him doing with it!!! Hmmm... I use a screwdriver as a chisel or pry bar sometimes and cheap calipers to scribe lines but a screwdriver isn't a chisel or pry bar and calipers aren't a scribe. Is it a fuel nozzle or just a nozzle? The answer is: It depends on what you use it for! Let's light a match and find out! :)
It is not allowed in my country, by law, water points near fuel pumps. The factors are obvious: leakage, corrosion, maintenance, etc. This gas station would have its license revoked if it did this! Watering cans are used to fill the radiators, so the only way to prove it is gasoline is to actually light a match. Would you dare to fill the tank at this gas station?
Even if it is water, having water come out of a fuel pump handle is a dumb idea; too easy for some dummy to pump water into his gas tank.
