Gear cutting on a CNC
Gear cutting on a cnc
In this video we will basically cut a gear from start to finish
we will cover how to setup and zero or touch off the gear cutting tool
By changing three numbers in the program you can cut any number of teeth and number of passes
and if you change the Y axis you can cut almost any Diameter size of gear
not bad for only 22 lines of code
If you would like to see more about sub programming the next video goes more in depth
Video link
https://youtu.be/pb-dBXCtMng
