Results 1 to 5 of 5
Thread: Gelatinized motor oil - GIF
Hybrid View
    May 2024
    mr mikey (Dec 3, 2024), nova_robotics (Dec 1, 2024)
    he just as well stop playing around and drop the pan
    Lake Tahoe
    IntheGroove's Tools
    That's what happens when you pour Flex Seal in your engine to stop the leaks...
  5. The Following 3 Users Say Thank You to IntheGroove For This Useful Post:
    Frank S (Nov 30, 2024), mr mikey (Dec 3, 2024), philippacificnw (Dec 4, 2024)
    Sep 2018
    nova_robotics's Tools
    That would be a bad case of antifreeze in the oil. I've seen this a number of times with blown head gaskets or cracked blocks. If a lot of antifreeze gets into the oil and is cooked with engine heat it turns the oil into this Jello like substance.
    If you can get it repaired quickly and before your journal bearings go out you can get the jello out with Varsol. Not saying they should, but they can.
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    Back in the sixties I worked at a gas station that had an engine flushing machine for cars that used non detergent oil back in in the 40' 50's etc. I never used it. One day a 1946 Ford came in for service and it had a drain plug that was huge. The boss told me it was that big so when the flush machine was used all the sludge could come out while solvent was pumped in. Crazy stuff.
  8. The Following User Says Thank You to mr mikey For This Useful Post:
    nova_robotics (Dec 5, 2024)
